Old 01-26-2023, 07:09 AM   #1
Neinris
Originally Posted by Compeer View Post
If i remember correctly the car had its ECU changed to suit the wheels at factory. With the right scan tool i was lead to believe you can change the speedo to suit the new wheel size. Could be wrong with the yaris tho but i know other cars you can do this.
Actually, it’s not my ECU/ECM, because I have a smart ODB gauge plugged in, which I can adjust the speed it displays, but I have it set to 100% and the speed it displays is accurate when compared to my GPS and the speed RADAR that I pass by on the way to work.
Old 01-28-2023, 04:31 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
My obd2 display shows same as my speedo is reading, I have the JDM RS vitz dash installed that did not come with the car and I changed that second day I owned it so this could also be why mines a bit off.
Compeer is offline   Reply With Quote
