polishing clear plastic like that is only ment for those with exceptional patience
ive not done it to a yaris but ive done it to countless old cars....pre 1980 and what i can tell you is that you will want to remove the lense take it in the house where ts warm and slowly work on it..youll need to start by figuring out how deep the damage of the scuff is...but your going to be sanding and polishing the ENTIRE lense, anything less will leave a permanent "smudge" in the finish if yoiu truely want to take it on plan on needing wet sand paper from 600 thru 2500 grit as well as various stages of polishing compounds if you want to try quick n dirty..you can try a headlight lense buff n polish but i dont reccomend it as the plastic of a headlight is 4x as thick and tough with that said tho i have had luck on small lenses where ive used nothing but the final 2 stages of polishing compound on a cotton wheel then 3 stages of rubbing compound...but this was on VERY fine scrtaches IE from NOS parts floating around in a box |
| 2012 Yaris SE Hatchback Instrument Cluster diode stuck on | 2012YariSE | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 07-12-2022 07:14 PM |
| Instrument Cluster Question | thebark | Cosmetic Modifications (Exterior/Interior) | 1 | 09-01-2016 03:47 PM |
| 2007 yaris instrument cluster dead and engine won't start | dchippowski | DIY / Maintenance / Service | 2 | 05-17-2015 11:00 AM |
| Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback | AndyW | Willing to Buy by private party | 6 | 12-07-2014 08:53 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
