Old 02-11-2023, 02:14 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by Neinris View Post
As you already know, my disc brake conversion is underway. I already have all the hardware necessary to complete the conversion, minus the materials for the brackets. But I'm looking into replacing the brake line from the hard line under the chassis to the caliper with one rubber hose, instead of transitioning from hardline to rubber hose, to hardline, to rubber hose connected to the caliper. This could give me the opportunity to reroute them, and just remove the brackets that hits the frame.
I think like Short says it needs the new hard brake line made up, I think it would be easier, just move the bracket on each side and have a new line made at a brake shop should not cost to much.
Compeer is offline   Reply With Quote
Old 02-11-2023, 01:59 PM   #2
sh0rtlife
again FWIW making hardlines is EASY and dirt cheep, even easier if you have the OE fittings cut from an old set of lines..at that point all you need is the right length of line and a a lil time with a flair tool....ive made countless amounts of line over the years, get a cheep flair tool and a few feet of line cut the ends off and flair repeate till you understand what your doing..after that making your line will take only a few moments
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
