Old 02-15-2023, 11:37 PM   #1
sh0rtlife
Originally Posted by Neinris View Post
Yaris rear wheel hub...
Attachment 62483
2nd GEN Scion xB rear wheel hub (5 x 114.3)...
Attachment 62484
Interesting...
Adding this to my "To Do" project.
is it the same axle mounting?...i mean 5x114 opens the world to basicly every wheel imagineable.....makes me wonder if the front spindle/hub is also the same "fit"
NO NO NO NO bad...im staying true to my 4x100...but the 1st gen toaster XB that will be soon.....hmmmmmmmm
Old 02-16-2023, 06:25 AM   #2
Neinris
Yes, my theory is that the 2nd GEN xB (xB2) also uses the Yaris/xD rear axle frame. If so, then the hunt for the Yaris SE rear axle frame stops and pursue looking for the 2nd GEN xB’s axle frame for rear disc conversion!!!
The front spindle for the xB2 are already pressed in the bearing, they do have the same spine count (26), and I think if you press them out, they’ll fit in the Yaris’ front bearings.
I should ask my neighbor if I can take measurements of his 2nd Gen xB.
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
