Old 02-16-2023, 07:01 PM   #1
sh0rtlife
ill see what i can do as i need to do an inspection on it...however initial eyeballing tells me that the axle/swing arm is a totaly different animal and the mounting points on the yaris are much further away from the axle as well as the "tie bar" between the 2 sides is about twice the size
that doesnt mean tho that any of the rest of the stuff isnt possibly the same
honestly tho on the "hub" unit i would just walk into any orielys/ autozone(i hate autozone) and ask them to order one in if they dont have one on hand..that way you could 100% verify the mountings
i will get what measurements i can tho
im actualy useing alot of you and compeers data to try and put something together for the gen1 xb that will be coming home soon..as i KNOW discs in the rear would be really nice on it..but also "bigger"...so if i can help figure stuff out in advance i can then be ahead of the game for a swap on it since it indeed uses all yaris bits under it..i mean its a yaris with a toaster body LOL
Old 02-20-2023, 10:17 AM   #2
Neinris
There are a few xB2 in the nearest Pick and Pull/LKQ near me, but still about 45 min drive, which has prevented me from going, especially now that it's still cold weather. Maybe in the summer time I'll see if I can snag the left and right steering knuckles and rear hubs out of one. I'd press out the front hubs out of the bearings, and take measurements to see if they'd fit in the front Yaris' wheel bearings and drive spline.
The Yaris SE's front rotors are 275mm O.D., which are what I have, the xB2's front rotors are also 275mm O.D.
Yaris SE front rotors:
Rotor Center Hole ID (mm) 55
Rotor Height (mm) 46
Rotor Hub OD (mm) 141
Rotor ID (mm) 130
Rotor Minimum Thickness (mm) 19
Rotor OD (mm) 275
Rotor Surface Thickness (mm) 22
xB2 front rotors:
Rotor Center Hole ID (mm) 62
Rotor Hub OD (mm) 155
Rotor ID (mm) 145
Rotor Minimum Thickness (mm) 22
Rotor OD (mm) 275
Rotor Surface Thickness (mm) 25
5X114.3 PCD here I come...
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
