Old 02-23-2023, 10:25 PM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by Neinris View Post
I bought my parts from RockAuto.com The rotors are as cheap as $16.50 each!
https://www.rockauto.com/en/moreinfo...t=1896&jsn=866
It's also where I bought the parking brake cables.
https://www.rockauto.com/en/moreinfo...t=1696&jsn=969
https://www.rockauto.com/en/moreinfo...t=1696&jsn=970
I'll do you a favor since you did me one, once I install the rear disc conversion, I'll see if I can find a 14" wheel, and see if it'd fit. And if I end up using the Corolla calipers with my disc conversion, I'll be selling the Yaris calipers I bought, I might even make the adaptor plates to go with them. That's only if I end up using the Corolla calipers.
haha hell yeah Shortlife gets to join the rear brake club too
Compeer is offline   Reply With Quote
Old 02-24-2023, 01:11 AM   #2
sh0rtlife
fwiw i have a deal in place for a gen1 XB...due to snow ive been unable to pick it up
but knowing the XB1 is neerly identical to the gen2 yaris...that means everything i pickup information wise should directly swap over to it...so ill be joining times 2!...thats assuming i dont just swap the xb1 to 5lug xb2 parts
Old 02-24-2023, 07:15 AM   #3
Neinris
Are you going to do an axle swap for both or plate adaptor?
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
