the condensor carrys no real amount of oil only oil vapor, and you shouldnt need to add any oil if only replacing components
as far as actual oil capacity the only way to be sure is to drain the pump and check directly with the compressor type and spec .....the specs are very specific to pump ID not year/make/model of the car and often times you have mid yer changes that may slightly change the compressor and how much oil its got |
#2 | |
A/C
#3 | |
so long as you have a vacume pump and the ac guages to do it yourself its actualy simple....even still if you dont, so long as you put in a new dryer and filter into a SEALED system your fine, i wish i could remember what oil i put in the compressor as it was used and i did a reseal on it along with new oil every stitch of tech i could find regarding oil is that yes..oil vapor travels with teh freon but should be minimal at best, the "important" oil stays with the compressor, any oil in the system with the freon is just a side effect that shouldnt be there |
#4 | |
freon
