Even with all the correct parts, the 2zr is not a direct drop in. It is as good as it gets for an engine swap, but far from a drop in. Lots of strange things happen that need to be solved and worked through after the swap.
One example is how my driver side axles were too long for the new 2zr swap and ended up binding in tight tur s. Solved it with a Tercel axle. Also need to deal with immo wires and MAF power.
| Tags |
| bearing, engine, swap, yaris |
| 3rd gen engine swap, 2ZR? 2AR? Swap newbie | m.flores.0928 | Third Gen Yaris General Discussion | 6 | 10-02-2020 10:54 AM |
| 2007 Yaris engine swap - 2NZ-FE to 1NZ-FE | duggy16v | Performance Modifications | 3 | 01-06-2018 08:35 AM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Rod knock or Main bearing knock? | jabranko | General Yaris / Vitz Discussion | 27 | 08-05-2011 11:14 AM |
