I’m not even sure oil filters are necessary. My1974 VW beetle didn’t even have an oil filter. I rebuild the engine at 130,000 miles and the main bearings, the camshaft bearings, and the rod bearings and their counterparts on the crankshaft and the camshaft had ZERO wear. At 250,000 miles when I took the engine apart to put it in a 71 VW bus there was still very little wear on those bearings. The cylinders and pistons We’re toast at 130,000 miles and again at 250,000.
It’s true I changed the oil every 1500 miles and it’s also true that the car was 90% of the time used to commute 30 miles to work. But there was no oil filter and only 2 1/2 quarts of oil in the engine. A quart of oil in those days was $.75.! Imagine doing a oil change for a buck 50!
![]() Drives: 07 Yaris Sedan S Join Date: Nov 2009
Denso is the OEM for Toyota filters. Else, you can get the Toyota oil filters from the dealership for like $3 or $4. You can go to parts.toyota.com and check the prices of the dealerships around you (they vary).
#3 | |
after my timing chain stuff...im not sold a filter does much too...since the VVT was full of shavings and the filter was nasty but should have still been catching |
#4 | |
And he’s got a compelling argument too!
#5 | |
hell only 2 of my bikes even have filters..the 03 zr7-s and the 83 honda xl600r with the way the "bypass" plate is designed in all filters..only about 1/2 of the oil is even filtered while the rest just uses the bypass...HEAT has alot to do with that as the hot oil makes the spring compress, to which i say..if you can add a cooler i recomend it as HEAT has alot to do with how your filter works...even better if you can do a sandwich plate and "remote" filter as then the filter isnt on the block sucking head further opening its bypass in the end a filter is really only designed to clean a little...and is there mostly for the guys who dont take care of their car.....think of it like an idiot light with my timing chain issues....i flushed more crap out of the engine WITHOUT the oil filter than the filter could catch...so...yeah |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Honda Ruckus' still only use a screen. Not sure about Honda's other 50cc mini bikes/scooters though.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
| What kind of oil temperatures are you getting? | Brettguy | General Yaris / Vitz Discussion | 7 | 04-18-2019 11:42 AM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Oil filter | regal | DIY / Maintenance / Service | 12 | 10-05-2009 12:36 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
