#1 | |
![]() ![]() Drives: . Join Date: Mar 2019
First there is an "easy out" or bolt extractor. You have to drill a hole in the middle of the bolt then drill in a reverse bit to help unscrew the messed up bolt I would modify this technique and start with drilling a hole for the extractor, then using a larger bit to remove most or all of the bolt head. With the bolt head gone, you can remove the seat and have more room to work. Also with the bolt head off, you'll have room to inject deep penetrating oil before the extraction to improve your chances of success. Down side: If the extractor breaks, you have a really big problem. Also see if the bolt holes go all the way through the frame (like the rear seat ones do) If so, you can hit the bolt from both sides with penetration oil. Also, if it's exposed, it might give you a second direction for extraction. Good luck! Last edited by CrimsonEclipse; 04-28-2023 at 12:34 AM. |
#2 | |
![]() Drives: 2009 Toyota Yaris Join Date: Feb 2023
Crimson, I'm on it. Thanks for the timely advice on how best to remove this stubborn bolt. I'll let you know how it turns out - |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness | Ric n Sov's Vitz RS | Items for Sale by private party | 2 | 10-19-2008 01:34 AM |
| What type of head unit with AUX port? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-06-2006 10:21 AM |
| SEAT BOLTS | 07WYarisRS | DIY / Maintenance / Service | 10 | 10-05-2006 04:38 PM |
| **CUSCO Type OS strut bars** | C2AUTOSPL | Sponsors Classifieds Area | 12 | 08-04-2006 10:35 AM |
