Old 04-28-2023, 01:50 PM   #1
sh0rtlife
did you swap 1 and 3 or 2 and 3?
1/3(bank1) 2/4(bank2) are grouped so you need to swap from "bank 2"
would also reccomend swaping the injectors around befor replacing
royal purple full system cleaner, run some in a tank once or twice a year and youll be pleasantly supprised...a friend pointed me out to that stuff, and ive never bought into the idea, but...ive not had to rebuild a bike carb since starting using it..if it can keep my bike carbs clean then injectors on something used daily is easy
Old 05-01-2023, 11:15 AM   #2
LostinSpace
Drives: 2010 Yaris
I did not think of this but thankfully I swapped 2 and 3 so I do believe the test still proves. I might give that Royal Purple a shot before replacing the injector. Thanks for the suggestions!
LostinSpace is offline   Reply With Quote
Old 08-18-2023, 05:01 PM   #3
LostinSpace
Drives: 2010 Yaris
Update:
Turns out it was due to a bad injector, bought a used OEM from eBay for $15 and slapped it in and rough idle and check engine lights all went away! So far no other issues, next thing on the list is to figure out why the airbag light is on
2006 Yaris head gasket replacement? jzr756 DIY / Maintenance / Service 1 04-30-2022 10:13 PM
Head gasket thefalls Forced Induction Forum 12 11-12-2012 12:26 AM
