Old 05-11-2023, 05:00 PM   #1
sh0rtlife
1.8 in a an echo?!?!?!?
anyone ever heard of it being done? or have links or info
ive been eyeballing some things and it seems that it would be similar to doing a 1.8 yaris, with the need of some rolla and XD parts, but the echo is throttle CABLE not fly by wire, so it would have to be an early rola 1.8
literally looking this info up more for the XB1 as ive dug thru it enough to be able to definitively say that 100% a XB1 is toaster on an echo chassis...the thing is the xb forums SUCK for this, those guys dont mind going slow n low they are less into engine mods...so if i can find someone who did an echo odds are it would be close enough for me to work with or maybe even be the exact same swap....engine mounts are the only "unknown" of xb vs echo
for reference echo vs xb1, same fans, rad, ac condensor, throttle body, engine, fuse box, engine harness..ive visualy verifyed that the rear axle is also the same as an echo..save for possibly the spring pockets
Old 05-14-2023, 03:23 PM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
I've seen a 2ZZ swap in an Echo, but no documentations... sorry...
Neinris is offline   Reply With Quote
Old 05-14-2023, 08:56 PM   #3
bronsin
bronsin's Avatar
Hey how about putting a 1 L in a Yaris or an echo? I’d be down for that!
Old 05-14-2023, 11:16 PM   #4
sh0rtlife
lol well just import one from japan then..the 1L was pretty common over there hell ALL of the AWD yaris are 1L
honestly im not even sure where outside of japan youd source the 1L for it let alone the brain and harness
Old 05-15-2023, 07:42 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
4WD Yaris were all 1.3L, early ones were the 2SZ-FE, later ones(facelift gen 2 and gen 3) had the 1NR-FE.
Europe and the UK got both the 1SZ-FE and 1KR-FE so in theory you could get the engine harness and ECU from there for either powertrain.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Can I use a set of 185/65/R14 tires on Echo? Echo123 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-28-2013 09:48 AM
Worst Cars of the 2000s (#4. Echo) MadMax General Yaris / Vitz Discussion 34 11-12-2009 11:41 AM
Toyota Echo and Yaris TWM Short Shifter Sale! TWM Performance TWM Performance 3 08-24-2009 11:50 AM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 03:23 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 03:13 PM
