Old 05-18-2023, 12:35 AM   #1
komichal
If you drive with your headlights turned on (which is likely the case as I doubt the 2007 was ever fitted with daylights) you can get 12V from the rear lights.
My experience: I bought a camera set that included front and rear camera and all the wiring. Some 100 Euros. Installation was mostly fun except for trying to push the usb cable through the rubber hose between the fifth door and the body. That was a nightmare and I destroyed that hose when I went berserk.
It all depends if you need the rear cam for security reasons or to help you navigate when backing up. Which is IMHO not needed for our motorized cupcakes.
Old 05-18-2023, 07:15 PM   #2
sh0rtlife
most 07s were fitted with DRL's but it doesnt kick the tail lights on
24v, power supply, rear camera
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
