![]() Drives: 2011 Yaris Hatchback Manual Join Date: May 2018
I've done this for most of my vehicles my old Geo metro my T100 and I just finished doing this with my 2011 Yaris
But I tend to take the two-tone horns from VW bugs which sound great and with the three-point bracket or easy Bolt on to where the old horn was, tie the ground ends together on body and run the other line to the horn wire. it's a very tight fit in the in the nose for that configuration can press up against AC components and damage stuff so I ended up mounting it in the driver side void right behind the bumper end using a bracket from a passat grounding both horns to the body and running an extra piece of wire from the horn line to the horns I'll have to pull my nose off again but I should get pictures of it and post it on here works great absolutely love it.
| DIY aftermarket steering wheel install with horn and airbag delete | tmontague | Performance Modifications | 19 | 11-30-2018 12:19 PM |
| Broken Horn FIXED! | zerosl | DIY / Maintenance / Service | 0 | 10-10-2017 03:14 PM |
| Horn Button Replacement | BobTheYaris | DIY / Maintenance / Service | 4 | 11-04-2014 01:22 PM |
| Yaris Horn install 15 Mins, WOLO 380 2T, Stock is too weak. | WRX | Third Gen Yaris General Discussion | 2 | 04-19-2014 10:07 PM |
| DIY Horn Replacement. | screenprintr | DIY / Maintenance / Service | 9 | 12-29-2012 01:29 AM |
