Old 06-04-2023, 07:36 PM   #1
sh0rtlife
so let me clear the presures up
the system requires X pressure, and the sensor must see the pressure..something above 20 and below 45 psi
next the comp kicks on and builds pressure, anything up to around 200psi before being shut down
my question to them when they say presures are fine would be..to see what the "high side" is with the engine running....if your getting correct pressures on both high and low side then the comp is FINE
the bigger issue with "old cars" is that inevitable someone will have put some stop leak in which plugs the pressure control orifice plate and is useualy the cause of most of the issues..its this same stop leak that tends to kill the pressure sensor
after that the best thing i can say to do is see if both the condensor and evap are unobstructed..you could even have a bad blend door in the heater or cabin filter
the only other thing i can say is that the toyota specs for ac fill are not "correct" by the ac manufacturer specs, whereas you dont set the system for cooling at idle but you set it at 1500rpm
AIR CON selant products mik23 DIY / Maintenance / Service 1 06-24-2016 12:40 PM
Simota CF650-6 Air Intake Review invader166 Performance Modifications 16 12-21-2015 03:31 PM
1nzfe and 2nzfe same air intake? Yaross Performance Modifications 9 09-14-2011 03:52 AM
Armchair theory - extreme cold air intake. Beer Jammer Performance Modifications 40 08-17-2010 02:00 AM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
