Old 06-08-2023, 06:47 PM   #1
Neinris
Originally Posted by sh0rtlife View Post
the rev hang will fix itself outside of "cold starts", the trick is to keep playing with the idle screw and you can eventually get it to be consistent ..its why i loctighted a torx into the screw itself so i can make slight adjustments...at this point tho its settled in and i havnt needed to muck with it
for referance the idle screw DOSE NOT adjust the stop point or the butterflys position, it changes the "tension" on the butterfly and the electric motor to hold open or hold closed the butterfly, so you cant treat it like a true idle adjustment....once you understand that your changing the positive/negitive "spring load" on the motor zero point it starts to make more sense as to why some adjustments do NOTHING.
the cars ecu ultimately tells the TB motor how much "load" is acceptable to maintain ilde, so with the screw you can add or remove load but its not a linear adjustment and is best made after taking it for a drive
My Dee Dee is a manual, the rev hang I'm talking about is when I shift gears. There's about a second or two delay that the engine is still revved up even if the throttle pedal is fully released and the clutch pedal is fully pressed.
The screw does change the spring load, but it also DOES adjust the stopping point of the butterfly. It's the same principle as a single stage height adjustable suspension, where you adjust the spring perch to adjust the height ride. I don't have the 1ZZ installed right now, and I can tell that when I turn the screw, the butterfly's opening either get bigger or smaller when I adjust it.
Old 06-08-2023, 11:45 PM   #2
sh0rtlife
i thought it did too till i had the unit apart and played with it without the spring installed..its got no "stop" in it its 100% motor tension on it
i wonder if your rev hang is "board" issue..could also be a worn out spring for that matter as the spring is the only thing that brings the butterfly shut
Old 07-02-2023, 04:20 AM   #3
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Hello Short,
Are you running a 1zz? I am thinking of doing this mod.
I am wondering how the 1zz effects fuel efficiency and if the torque is increased? If it helps my car up hills without too much of a fuel use penalty I wish to give it a shot.
Calrenman is offline   Reply With Quote
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 06:13 PM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
