Old 06-08-2023, 11:45 PM   #1
sh0rtlife
Originally Posted by Neinris View Post
My Dee Dee is a manual, the rev hang I'm talking about is when I shift gears. There's about a second or two delay that the engine is still revved up even if the throttle pedal is fully released and the clutch pedal is fully pressed.
The screw does change the spring load, but it also DOES adjust the stopping point of the butterfly. It's the same principle as a single stage height adjustable suspension, where you adjust the spring perch to adjust the height ride. I don't have the 1ZZ installed right now, and I can tell that when I turn the screw, the butterfly's opening either get bigger or smaller when I adjust it.
i thought it did too till i had the unit apart and played with it without the spring installed..its got no "stop" in it its 100% motor tension on it
i wonder if your rev hang is "board" issue..could also be a worn out spring for that matter as the spring is the only thing that brings the butterfly shut
Old 07-02-2023, 04:20 AM   #2
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Hello Short,
Are you running a 1zz? I am thinking of doing this mod.
I am wondering how the 1zz effects fuel efficiency and if the torque is increased? If it helps my car up hills without too much of a fuel use penalty I wish to give it a shot.
Calrenman is offline   Reply With Quote
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 06:13 PM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
