Driver
Drives: 2008 Yaris LE Join Date: Oct 2020
Thanks for the "next steps" and suggestions people :)
Measurement Readings are as follows (I tested it with two different gauges - results slightly different between the two): Coolant "burped" as needed. Resistance of coolant sensor is around 2 ohms cold. Resistance of the coolant sensor wiring is around 3.75 ohms. Updating... Coolant temperature idling at 61*C after 10 minutes...rpm's around 1,000 And after a drive with 33*C intake coolant is now 81* C !!!!!!!! Success! Besides the two days and countless hours spent to achieve this, I'm glad this little engine "could" run right once again. I don't know why it wouldn't kick properly beforehand, but I'm happy now. Nina |
| Bad Idle | mamun22s | DIY / Maintenance / Service | 4 | 11-23-2013 09:24 PM |
| high pitch noise at idle | mokmok | DIY / Maintenance / Service | 19 | 12-24-2012 08:50 AM |
| Problem with low beams and High Beams | thebarbrr | DIY / Maintenance / Service | 7 | 09-22-2010 09:43 AM |
| High Beam Issues | urbanmindz | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 03-19-2009 10:22 PM |
