Old 08-18-2023, 05:01 PM   #1
LostinSpace
Drives: 2010 Yaris
Originally Posted by sh0rtlife View Post
did you swap 1 and 3 or 2 and 3?
1/3(bank1) 2/4(bank2) are grouped so you need to swap from "bank 2"
would also reccomend swaping the injectors around befor replacing
royal purple full system cleaner, run some in a tank once or twice a year and youll be pleasantly supprised...a friend pointed me out to that stuff, and ive never bought into the idea, but...ive not had to rebuild a bike carb since starting using it..if it can keep my bike carbs clean then injectors on something used daily is easy
Update:
Turns out it was due to a bad injector, bought a used OEM from eBay for $15 and slapped it in and rough idle and check engine lights all went away! So far no other issues, next thing on the list is to figure out why the airbag light is on
LostinSpace is offline   Reply With Quote
2006 Yaris head gasket replacement? jzr756 DIY / Maintenance / Service 1 04-30-2022 10:13 PM
2011 Toyota Yaris Head Gasket Issue mosschief DIY / Maintenance / Service 0 05-11-2021 02:20 PM
07 Yaris S Blown Head Gasket? ylerT DIY / Maintenance / Service 7 06-26-2013 01:19 PM
Head gasket thefalls Forced Induction Forum 12 11-12-2012 12:26 AM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
