Old 10-23-2018, 04:16 PM   #289
Sparty
Drives: 2007 Yaris
Hi everyone,
I have a US Model, 07, M/T, 1.5L, 3 door hatch. I'm installing this CC solution and I'm at the point where I'm running the D3 connector to the ECM pin 40. Please see the pic below. Which wire and pin do I send to the ECM and which one do I ground? The picture of my Yaris is different then the pictures in the instructions from CTScott. Thanks!!
https://share.icloud.com/photos/04lH...ah7sf_DqrWtH0A
Sparty is offline   Reply With Quote
Old 10-23-2018, 06:29 PM   #290
DarkShadowFox
Originally Posted by Sparty View Post
Hi everyone,
this is the 2012 forum and up. the changes are different subtle but different.
Old 10-29-2018, 05:08 AM   #291
Civic_JDM
Drives: KSP130
Interesting that both of the Greek 1.33 are not working. Can either of you give me the part number of your ECM (engine computer)?
Hello CTScott,
Please help to confirm if ECM # 89661-5C340 (Japnese spec, 1.0L engine i.e. 1KR-FE) support cruise control?
Civic_JDM is offline   Reply With Quote
Old 12-05-2018, 12:35 PM   #292
petros37
Drives: Yaris 1.3 europe
Hi
I have yaris 2013 1nr-fe 1.33 engine europe specs and installed the cruise stalk .
The problem is the indicator at the instrument cluster doesn't lit .Otherwise the cruise control works just fine .
Is it possible to fix this problem ?
petros37 is offline   Reply With Quote
Old 12-05-2018, 01:46 PM   #293
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Originally Posted by petros37 View Post
Hi
Which instrument do you have.
If its the basic one without RPM meter it probably also dont have the cruise light.
Then you can switch it to one of these which should have cruise lights, my car has it.
https://www.ebay.de/itm/Toyota-Yaris...p809:rk:2:pf:0
https://www.ebay.de/itm/Toyota-Yaris...UTE:rk:36:pf:0
https://www.ebay.de/itm/Tacho-Kombii...MAAOSwyWlbpqhd
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 12-05-2018, 03:53 PM   #294
petros37
I have the one with the RPM meter and i am sure that it has the cruise
light because i can see it with a flashlight but for some reason the light don't lit .
Maybe it's something that need to be unlocked through toyota diagnostic
computer or something else that i don't know .
Old 12-05-2018, 11:15 PM   #295
Civic_JDM
Drives: KSP130
Dear Experts
Old 03-01-2019, 03:03 AM   #296
Stargate
Drives: Yaris Active 2018
Ciao, have Active Yaris 2018. I can't open for install Cruise control. Can you help me. Thanks
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
Stargate is offline   Reply With Quote
Old 03-01-2019, 11:35 AM   #297
stykerdk
https://www.youtube.com/watch?v=H8r_oUV_plI
Old 06-23-2019, 08:17 AM   #298
S4F1S
Drives: 2019 Yaris HSD
Came here through Google. Got a brand new 2019 Yaris Hybrid (EU model), given to me by my employer (it's a 4 years lease). First off, I'm really impressed with the build quality and level of equipment for a base model. I do a lot of highway driving, so cruise control is a must for me. I bought a "cheap" stalk on eBay, received it on Friday and yesterday I installed it. Unclipping the airbag was a PITA, but finally I got into the steering wheel. Installed the stalk and drove off to test it. Everything works great. The 2019 steering wheel is again different, so the usual covers sold out there, don't match. Ordered the correct one from Toyota. It was 5€ and delivered in one day. Part code is: 45186-0D030-C2
Few Photos...
S4F1S is offline   Reply With Quote
Old 07-01-2019, 04:23 PM   #299
Spidious
Spidious's Avatar
Drives: 2010 Toyota Yaris 5dr
Been thru this twice. If I have to plug in the cruise wires in the steering wheel connector which and what colors ? I have a 2017 Yaris L
Spidious is offline   Reply With Quote
Old 07-22-2019, 09:03 PM   #300
Zippy_2019
Zippy_2019's Avatar
Drives: Hatchback
DIY Cruise Control for 2012 Yaris - Good News!
IMG_0246.jpg Here is a picture of the cruise control connector to the steering for a (US) 2017 L base Hatchback with volume controls (empty slot on right). There is only one way to connect the clip.
Zippy_2019 is offline   Reply With Quote
Old 08-31-2019, 06:06 AM   #301
Umarzafar88
Drives: Vitz 2011 with 1NR-FE engine
Plz help whether 1NR-FE 1.33 dual vvti CVT with ECU # 89661-52Q90 has built in cruise and ASL function?
And ECU pin out required? Or pin number for CCS and ASL for spiral cable installation.
Thanks
Umarzafar88@gmail.com
Sent from my LYA-L09 using Tapatalk
Umarzafar88 is offline   Reply With Quote
Old 02-28-2022, 06:14 AM   #302
Immanuel
Drives: Yairs 2015 hybrid
Yaris hybrid 2015 CC install
Can I install CC on my 2015 Yaris hybrid? Has anyone tried? Can anyone tell me if it will work? Thanks
Immanuel is offline   Reply With Quote
Old 01-01-2023, 10:08 PM   #303
storyofakid10
Drives: Toyota Yaris 2012
^Nice!
By the way, I recently acquired a batch of the replacement covers for the side of the 2012-2013 steering wheel, which have the hole for the cruise control stalk. They are $5 shipped in the US.
Hi CTScott, I know this post is now 10 years old, but I am looking to install a CC stalk on my 2012 Toyota Yaris and am wondering if by any chance you are still selling the side steering wheel covers (with cutout for CC stalk) for $5? I am in the US. Thanks
storyofakid10 is offline   Reply With Quote
Old 07-20-2023, 04:33 PM   #304
lancap
Drives: Toyota Yaris NPL130L
Hi,
May someone help me, already sent a post, and had some help, but Am stuck.
( Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > DIY / Maintenance / Service
2014 Yaris Cruise Control - No Success )
I have this Yaris:
NLP130L-CHFNXW (2014 European Model MT)
ENGINE: 1NDTV 1400cc Diesel turbo
Can someone tell confirm the CC will not work on Yaris Diesel Models?
Thanks
Kind regards
lancap is offline   Reply With Quote
Old 10-10-2023, 05:23 AM   #305
velle
Drives: xp130 d4d
same here, no luck. from what i ve researched you will also need to route pin cables through the wheel to the ecu
velle is offline   Reply With Quote
cruise control. 2012
