Old 11-04-2023, 08:20 PM   #1
Billiam
Drives: '10 White Yaris 4D LB
Removing the rear bearings aren't easy if they have never been off. However, there are some tricks that allow for removal without much drama.
Back in the spring of last year I was unable to locate a new one. In fact, my local dealer said there was a national back order and a wait that could be measured in months. That situation may have changed.
As for a used axle? I hope your mechanic is very careful. The first 4 that I found were in just as bad a shape as mine. Thankfully a local salvage yard was able to locate a Scion xD axle.
The Yaris, Prius C and Scion xD use the same axle if that helps the search.
If you want to enjoy your car, stay off of the internet.
Old 11-06-2023, 06:06 AM   #2
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Great information about the rear axle cross reference!
Thank you for putting that info out!
Calrenman is offline   Reply With Quote
Yaris Hatchback 2016 rear axle beam compatibility nhu001 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-28-2022 04:32 AM
rear stablilzer in 2010 sedan..any thoughhts jay cobbs General Yaris / Vitz Discussion 0 06-08-2012 10:00 AM
