Old 11-24-2023, 04:37 PM   #1
remcafee
was the differential preload in spec? or did you have to change out the shim? im curious as to how to remove the bearings in the case
Old 11-26-2023, 01:07 AM   #2
rpster
Drives: '07 Yaris Liftback
I didn't bother to measure the preload on the old bearings prior to teardown since I knew I would be replacing the differential bearings anyways. I went from the "DD" shim that was previously installed to an "EE" and got my preload on the high range of spec for new bearings (0.78 to 1.57 Nm)
Unless you have a very large press, I used a deadblow with an appropriately sized socket to push the old bearings out.
rpster is offline   Reply With Quote
Toyota Echo Trans Swap (Auto -> Man) es604 Performance Modifications 2 07-29-2022 08:03 PM
Manual To Auto bronsin General Yaris / Vitz Discussion 10 12-22-2008 10:32 PM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 08:45 PM
