Old 11-29-2023, 11:34 AM   #5
Lucas@AirLift
GRIDLIFE Sundae Cup Yaris
Drives: 06 CDN Yaris Base
Originally Posted by Compeer View Post
Really bloody cool! get it done I will buy one and fit it to be another test dummy!
Honestly, if you covered shipping costs from MI, USA to you in NZ I will send you it for free to test out. I have a total of maybe 4 hours in design time in to this, and it costs ~$2USD in material to print one out.
I couldn't wait for my lunch break so I snuck out of work and threw it in the shifter really quick.. and it works perfect! With the 2" shifter extension I am running, I measured a full lateral travel of ~4.5" stock. With this printed arm I measured ~4" which is about a 12% reduction in lateral throw! In the V1 model I moved the pin 10mm farther from the pivot to get this reduction. I am going to do the V2 in 2 different flavors, 10mm and 15mm. The 15mm should drop the lateral throw by at least another 5%. Personally I LOVE how it feels at this point, but I think others may want it shorter.
So here are the pics. I have learned from my 3d print adventures in the gun cad world that pegs that come from a flat surface are super weak and will likely fail. To combat this, I drilled and tapped the shifter peg with a 6-32x3/4" button head screw, and I can SLAM the shifter side to side and it did not damage the part! I am also using a bolt to replace the broken spring peg on this revision. The final will have a 6-32 bolt on both pegs to prevent breakage.
Lucas@AirLift is offline   Reply With Quote
The MI SSK "Not a Big 'Car Guy'" Review jpmck03 Performance Modifications 36 09-19-2013 11:41 PM
Toyota Echo and Yaris TWM Short Shifter Sale! TWM Performance TWM Performance 3 08-24-2009 10:50 AM
Homemade Short Shifter Not Short Throw kit ImportRacer88 Cosmetic Modifications (Exterior/Interior) 10 12-17-2008 03:17 PM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
