Old 01-11-2024, 09:25 AM   #1
Sílfa
Sílfa's Avatar
Drives: Toyota Corolla
In this instance, the retainer needed to be tightened to 540 degrees clockwise from the starting point and aligned to the marks on the tank.
Sílfa is offline   Reply With Quote
Old 01-13-2024, 07:52 AM   #2
Branderrp
Drives: Yaris 2006 NCP91R
I did do that before which surprisingly didn't work. The mechanics told me I actually did everything correctly on the manual but it still didn't seal properly for some reason. They said it was a design issue with Toyota since they had a similar issue with Corolla's doing that. Fortunately there hasn't been any issue since
Branderrp is offline   Reply With Quote
Tags
fuel, gasoline, leak, pump, smell
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
Fuel pump whine after filter replacement kivig DIY / Maintenance / Service 1 10-08-2018 05:59 PM
Aftermarket Fuel Pump BoostedTRD Forced Induction Forum 5 10-29-2014 05:31 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 12:21 PM
