Old 01-29-2024, 09:19 PM   #1
YOUNG SCOOTER
Drives: 2008 Toyota Yaris Hatch
flashing or solid tire warning light after multiple checks of air pressure
Tire light flashes upon startup and then goes solid for the rest of the drive. Tires were all at 24 psi so I aired them up to 34psi VERIFIED with an electronic gauge. Many restarts later and the light wont go off. In years past the light would go off if the tires were inflated back to spec.
YOUNG SCOOTER is offline   Reply With Quote
Old 01-30-2024, 07:13 PM   #2
ex-x-fire
When it flashes it's telling you there's a fault, not low air pressure. Have the sensors scanned for activity.
Old 01-31-2024, 07:50 PM   #3
YOUNG SCOOTER
car is pushing 200k miles. its also my first car with tpms. I think I'm just gonna go old school and remove the bulb and just eyeball the tires like decades past.
Old 02-02-2024, 02:22 AM   #4
CrimsonEclipse
Drives: .
There's a wire mod on the sensor module under the glove box that just fools the system into thinking everything's ok.
Then it won't throw codes during inspection.
CrimsonEclipse is offline   Reply With Quote
Old 02-01-2024, 10:59 AM   #5
remcafee
i wouldnt mess with the cluster if i were you, especially with 200k miles the plastic tabs that hold it together will break and the cluster will never get put back together correctly again, it will have rattles, loose gaps and things like that, ask me how i know
Old 02-01-2024, 08:07 PM   #6
Compeer
Drives: NCP90 TRD Yaris Manual
You always start simple first and in this case its replacing the wheel sensor inside your factory rim, they have a battery and commonly stop working so start there.
Compeer is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Several warning lights supra9691 DIY / Maintenance / Service 5 02-28-2022 01:00 AM
Recommended tire air pressure for 17"? W.A.S.P Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-26-2007 05:20 AM
