Old 03-04-2024, 12:02 AM   #1
woolongdev
Drives: scion xb
found some interesting info on using the jdm u340e in usdm cars.
The wiring for the solenoids is a little different.
https://www.drive2.ru/l/561243512448747398/
Accord to this, the easiest option would be to add a wire into the vehicle side of the harness (pin#7)and run it to ground.
This will allow the lockup solenoid to operate.
woolongdev is offline   Reply With Quote
Transmission swap 05 Echo suprf1y Performance Modifications 18 03-30-2019 09:00 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
TPMS Issues After Wheel Swap pulsar2121 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-07-2015 05:38 PM
transmission swap kralmrax DIY / Maintenance / Service 5 07-22-2006 01:04 PM
