Old 03-31-2024, 10:18 AM   #1
Billiam
Drives: '10 White Yaris 4D LB
I would be more concerned with the lower control arm bolt corrosion and the condition of the welds on the rear axle beam where the beam and trailing arms are welded together.
If you want to enjoy your car, stay off of the internet.
Old 04-01-2024, 08:01 PM   #2
CrimsonEclipse
Drives: .
Originally Posted by Billiam View Post
I would be more cocerned with the lower control arm bolt corrosion and the condition of the welds on the rear axle beam where the beam and trailing arms are welded together.
How the heck do you check for lower control arm corrosion on a pre buy walk around?
CrimsonEclipse is offline   Reply With Quote
Quick Struts for 2011 Toyota Yaris pkostov86 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-15-2019 11:31 AM
4WD Yaris / Vitz questions Swing Performance Modifications 29 11-29-2016 06:36 PM
2011 Yaris with 230k Miles---Smart Purchase? Pixydish General Yaris / Vitz Discussion 10 04-10-2016 07:09 PM
