Old 05-10-2007, 05:11 PM   #1
kurokoma-kun
Drives: 2007 Yaris HB
You are talking to a girl here... i know which is bizness end of hammer and can jerry rig stuff pretty well but wtf is a mandrel?
Old 05-10-2007, 05:23 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
I just walked out to the garage and put mine on for the first time and they are snug. Take a cresent wrench (adjustable) and tighten it on the inner skirt of the grease cup. Make a slight bend inward (I did it in 4 places) and test fit. When I had the cap snugly fitted I just taped them on with a rubber mallet until they where seated. Let me run them a few days and I will give you an update.
blacksan is offline   Reply With Quote
Old 05-10-2007, 05:34 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Glad to hear you found them BLACKSAN
Old 05-10-2007, 05:56 PM   #4
blacksan
blacksan's Avatar
I was kind of shocked to find out that they where too big? I polished them up and bent/tweaked them until they where sung. I am going to find a better system of fastening them this summer, or caps that actually fit the ID vs OD of the wheel hub.
Old 05-10-2007, 06:31 PM   #5
Chris07LB
Chris07LB's Avatar
Should have measured them first then. I guess the Scion steelies arn't the same then afterall.
Old 05-10-2007, 06:36 PM   #6
blacksan
blacksan's Avatar
I did not study the pics of Scion wheels closely, but I can not imagine they are not the same. Does this look like it is on the outside, or inside of hub to you?
Old 05-10-2007, 06:27 PM   #7
kurokoma-kun
Take a cresent wrench..Make a slight bend...etc
Thanks for explanation--I may try it when these pop off eventually...
will be looking for pics blacksan
Old 05-10-2007, 06:31 PM   #8
blacksan
blacksan's Avatar
Let me make shore that this works and I will get you visual explanation of the procedure.
Seat cushion for thigh, center armrest left armrest BMGYaris Cosmetic Modifications (Exterior/Interior) 2 07-03-2009 11:51 PM
Hub Caps?? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-15-2007 11:34 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
