3000 rpm at 110kph is right on par. Keep in mind that the bigger the engine displacement, the lower it will rev. The Camry with the larger engine will naturally rev lower. At highway speeds, a V8 will be sub 2000rpm.
When it comes to efficiency, 6 to 6.5 l/100km can realistically only be achieved under optimal driving conditions. For the average Joe, this would be cruising on open highway at a steady 80 kph. No stops, starts or changes in acceleration.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
It's normal for the transmission to downshift when you brake.
If you use cruise control, it will also downshift to slow down as you go downhill. At the same time, the ECU will stop injecting fuel, so the current consumption display will drop to zero. My son drives my Yaris to work 4 days a week in a 20 km round trip. Average fuel consumption now displays 7.3 litres per hundred kilometres.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 | |
![]() Drives: 2014 Yaris YRS Join Date: May 2024
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-03-2026 12:44 AM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 03:35 PM |
