Old 07-29-2024, 11:53 PM   #1
CarpeDiem
Drives: 2008 Yaris Sedan
Hey guys, I got the kit today and installed the CC in a 2008 Yaris (no cruise light)...fast forward and I can't seem to get it to work. Did some troubleshooting over all connections (Pins are fully seated), checked the ground and the connection at the ECM all seem fine. When checking the voltage at D3 pin1 I have 13.3V, hold down the on/off switch and still 13.3V (not going to 0V). Could it be possible that the offshore Amazon stalk is bad out of the box? Any thoughts?
Thanks in advance
CarpeDiem is offline   Reply With Quote
Old 10-13-2024, 06:17 PM   #2
Cris_co1221
Drives: 2007 Yaris 3dr
Thanks in advance
I am having the same issue, but a 2007 3dr manual. I have all oem parts but cc not working, and same voltage issue when depressing the on/off switch.
Cris_co1221 is offline   Reply With Quote
Old 10-19-2024, 06:41 PM   #3
Cris_co1221
My issue was pin #2 on d3 wasn’t fully inserted (ground wire), got that hooked up and am fine now.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
