Old 02-10-2019, 08:42 AM   #1
2bz
Drives: 2008 Yaris 3DR Hatch MT
VVT Oil Control Valve Filter Replacement (the other oil filter)
I spent an hour plus, yesterday replacing the VVT OCV oil filter on my kid's 2008 Yaris. I figured that I would write a post and save everyone a lot of trial and error.
Here is what you will need:
- 8 mm ball end hex key. https://www.harborfreight.com/hand-t...set-61966.html
- Filter, Toyota P/N 15678-21010, reference number 15678A on the diagram below. https://parts.toyota.com/p/Toyota_20...567821010.html
- 12" piece of 3/16" ID copper tubing.
- Rag for catching oil.
The process:
1. This filter is located in the cylinder head, under a cap, which is behind the alternator.
2. Stuff a small rag under the filter plug behind the alternator.
3. Insert the 8 mm allen key into the filter plug by going over the top of the alternator from the front of the engine bay. Remove the plug and washer.
4. The filter is recessed about 1" behind the plug. Insert the copper tubing into the filter recess and press the prongs on the end of the filter into the hole in the tubing. This will allow you to remove the old filter. (Figuring this out took .75 of the hour.).
5. Insert the new filter.
6. Replace the plug and washer and tighten. (Sorry, no torque spec.)
7. Remover the rag.
8. Check for leaks.
Cheers.
2bz is offline   Reply With Quote
Old 02-10-2019, 09:47 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
VVT Oil Control Valve Filter (OCV) Replacement
Super post.
Any evidence of collected matter in filter?
(VVT Oil Control Valve Filter Replacement)
Old 02-10-2019, 09:53 AM   #3
2bz
Originally Posted by dogsridewith View Post
Super post.
What is the filter part number in the drawings?
Not sure what you are asking WRT the drawing part number?
Filter was pretty clean (a couple of flecks) after 102K miles.
Old 02-10-2019, 01:39 PM   #4
JDJanitor
Drives: 2016 yaris
Do you feel it needed replacement at 100k? Could it have gone to 200k miles on original?
Sent from my moto x4 using Tapatalk
JDJanitor is offline   Reply With Quote
Old 02-10-2019, 02:34 PM   #5
2bz
Talking
Remove, clean with carb cleaner, replace would work......if I didn't break it getting it out (use the copper tube method).
Old 07-31-2024, 07:46 PM   #6
busancun
Drives: 2010 Toyota Yaris
Smile What is the copper tube? Any info about the size and where to get it?
busancun is offline   Reply With Quote
Old 08-01-2024, 11:24 AM   #7
thetut
Drives: 2007 4dr sedan
Read post #1
thetut is offline   Reply With Quote
Old 08-02-2024, 03:44 AM   #8
komichal
Good post, thanks for this.
I was surprised when I screwed out my filter, it was absolutely clean, at least it looked like that (143000 miles). I gave it a proper wash in brake cleaner anyway and screwed it back.
CHECK ENGINE !!! Dealer Blames (Oil Control Valve) netspec239 General Yaris / Vitz Discussion 15 08-11-2018 04:31 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Oil Control Valve weston_sagle Willing to Buy by private party 4 07-10-2011 09:03 AM
WTB: Oil Control Valve/VVT Valve bdc87 Willing to Buy by private party 4 05-22-2009 09:15 PM
