Old 08-30-2024, 10:07 AM   #1
Brynmor
Drives: 2011 Yaris
I had a similar issue with my old car. It sounds like a bearing issue, probably the input shaft bearing. If it's just making noise while idling and not causing problems when you drive, it might not be urgent, but I'd still suggest getting it checked out by a pro. I've tackled strut replacements and oil changes myself, but gearbox stuff is a whole different level. Better to have a mechanic handle it to avoid making things worse.
Brynmor is offline   Reply With Quote
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 12:59 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Gearbox breaks at 110,000km on Yaris 2007 sven337 DIY / Maintenance / Service 10 07-26-2014 07:06 PM
Alternator Bearing barryware DIY / Maintenance / Service 7 11-23-2013 06:33 PM
