Old 09-21-2024, 05:43 PM   #1
funky2nite
Drives: 2013 Hybrid 1.5L T4
Talking Issue seems resolved - thanks God
Anyone that encounters this issue,
The way I apparently fixed mine is as follows:
Tracktion control light stopped showing after the second trip from when it lit up. But might also go away by disconnecting the 12v AUX battery under rear seat.
The hybrid system was restored again by either disconnecting aux battery for 5 minutes OR under the hood in the corner next to the orange HV cables there's an fusebox called HV, open it up and there's a fat white wire, using a flat head screw driver disconnect it for 5 mins then reconnect it, then turn key to on position BUT not to start the car, wait 5 seconds, thwtn turn key off again and this time turn key on until you start car and EV system shall be reset. In my case it become possible again to use car in EV mode or hybrid.
As after the bump EV mode/hybrid system got disabled. I suspect the batteries moved by few mm with the bump and caused the hiccup in the EV system and for safety it disables whole EV system until it's reset.
There's a clip on yt on how to reset hybrid system toyota.
funky2nite is offline   Reply With Quote
