Old 10-02-2024, 02:24 PM   #9
ElMagnifico
Drives: 2012 Sedan
Originally Posted by sh0rtlife View Post
the only addition i see needed for said PDF is that atleast for an 07, you need to add a ground wire to the stalk harness on the far right top 2 slot area the tiny pin...the single all by itself over there, the other 2 on the other end on the top are also for the fog, they give feedback to the ecu, the ground is required to actualy get the fogs to fire
I grounded that pin and it didn't work for me.
On vehicles that have that pin wired in the harness, where does it output to? Meaning, if i want to copy the stock wiring, where would i have to run that wire and connect it to?
ElMagnifico is offline   Reply With Quote
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
2004 Canadian Echo Hatchback Fog light Kit ( OEM Style ) mpcv2000 Cosmetic Modifications (Exterior/Interior) 26 04-06-2017 01:25 PM
Driver side reverse light power issue xdr3amx007 DIY / Maintenance / Service 1 03-22-2016 03:44 PM
OEM Fog Light Brackets? xavior686 Cosmetic Modifications (Exterior/Interior) 15 02-16-2014 01:04 PM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
