Old 10-15-2024, 07:13 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by Turbiini View Post
Beautiful build bro about to mod a honda one myself. How did she change performance? and how does the stock ecu like it?
Compeer is offline   Reply With Quote
Old 10-20-2024, 01:44 AM   #2
Turbiini
Drives: 1983 carina 2NZ-FTE
stock ecu works fine no dtc and every obd test pass. some ecu versions may be different results. This is euro3 emission manual trans version. Little more power on high revs under 4000 may lost some.
Problem for testing is there is some wrong with engine, it has dear spot on power output 4500-5500rpm even with stock intake. i thing it may be some mechanical noise for badly maintain high mileage engine. knock sensor hears piston slap or something an take ignition timing way down.
I have spare denso ecu with same connectors from my suzuki baleno. so install migrosquirt module in it. now engine works fine, now i also can remove maf or made bigger size maf tube.
Turbiini is offline   Reply With Quote
Old 11-18-2024, 12:57 PM   #3
Compeer
Cool bro, how does it drive now? Opens up and accelerates faster you think?
Also come join the Yaris Nexus discord bit more active there https://discord.gg/j4299STP6x
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Custom Short Ram Air Intake Problem laxsaint99 DIY / Maintenance / Service 10 04-27-2011 01:28 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
My Custom Intake RacerFreakXXX DIY / Maintenance / Service 7 12-21-2008 07:32 PM
