Old 01-02-2025, 05:48 AM   #1
HDS
Drives: 07 Yaris, Saab 900 Turbo
I've now welded it up, had to remove the rear axle completely.
Right side, ended up cutting a lot more than shown here.
New bottom plate with welded nut.
2mm sheet metal, painted with zinc primer.
Left side
Used a red primer to start with but switched to the gray zinc primer.
Also treated the rear axle with penetrating rust treatment (dinitrol ml) and then brushed it with a bitumen/oil based rust proofing agent.
The whole underside and cavities are being treated with dinitrol ML right now, then I'll also apply the same bitumen and oil based stuff over that once it has dried.
Car should have a few more years in it now.
HDS is offline   Reply With Quote
Rear Passenger Area Power Outlet DIY - Sedan fnkngrv DIY / Maintenance / Service 4 04-04-2019 07:03 AM
rear wiper arm delete Giammarco36 General Yaris / Vitz Discussion 20 05-16-2010 09:03 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
