Old 02-06-2025, 07:26 AM   #1
Gdawgs
Drives: 2010 Yaris
It sounds like you may have a little air in the clutch system. Bleed that and I believe your issue will go away.
I have an old MG midget that does the same thing. I have to bleed that every year or two.
Hard to say on the squeak. Have someone press the clutch in and out while you are under the hood and see if you can figure out where it's coming from.
Gdawgs is offline   Reply With Quote
Alternator/Serpentine Belt Squealing 2007 Yaris 1NZ-FE Engine nighthawk421 General Yaris / Vitz Discussion 4 10-27-2020 08:09 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
