Metal on aftermarket is not as good as OEM, but good for several more years of running. Just have the union between old and new clamped, not welded. Cheap enough that if it fails, replace again. Also, a welded joint on old pipe almost certainly guarantees that your next point of failure will be that weld.
#2 | |
![]() Drives: 2009 Yaris Hatchback Join Date: Mar 2025
I'm taking her Yaris in on Friday and will post back to you that afternoon. Hopefully the tiny crack can be welded, if not, then I will get that pipe |
#3 | |
https://www.magnaflow.com/products/5...E3VC3N_ug6LZPL |
