Drives: 2006 Yaris Join Date: Jul 2025
2006 Yaris No Crank
Looking for advice — I’ve got a 2006 Toyota Yaris that won’t crank when I turn the key. Dash lights come on as normal, but when I press the clutch and turn the key to start, the dash lights go out and nothing happens. The car sat for about 2 months before I bought it and apparently it started fine before that however the battery is completely dead so I replaced it with a new one.
Here’s what I’ve tried and confirmed so far: • Battery is brand new and fully charged • Battery terminals are clean and tight • Starter motor works — I applied 12V directly to the solenoid spade terminal and it cranked and engine started and ran fine • Starter relay is good (tested it out of the car) • Clutch pedal switch is working (I’m guessing as the dash lights only go out when pedal is pressed, so the circuit is activating or am I wrong ) • Ground from battery to engine is solid • No voltage is reaching the solenoid signal wire when trying to crank • Tested with multimeter on the solenoid’s spade connector — got 0V when someone turned the key • Fuses are all good Seems like the wire from the starter relay to the solenoid is either broken, corroded, or disconnected somewhere — just wondering if anyone else has had this issue or knows a common failure point? If anyone’s got any other suggestions then let me know Thanks |
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
| Yaris 2006 TRD yaris grill | Yaris2006RS | Cosmetic Modifications (Exterior/Interior) | 0 | 01-14-2013 10:17 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| 2006 Yaris YRX stock seat ~ | jaspie | Willing to Buy by private party | 0 | 01-13-2012 06:09 AM |
