![]() Drives: 2015 blue Yaris Join Date: Jan 2024
After 10 min of idling the coolant temp was just under 180F. I measured the upper radiator hose at an inside bend in the hose and it was 120F. I measured the lower radiator hose at a similar inside bend in the molded hose and it was 80F. So it seems the thermostat is staying closed when it should.
| Auto high beam mode doesn’t work… | baseballfan416 | Third Gen Yaris General Discussion | 0 | 10-02-2023 11:21 PM |
| 2007 ac swap, will update untill finished/solved | sh0rtlife | DIY / Maintenance / Service | 32 | 06-21-2022 02:01 AM |
| LOW RPM @Idle speed = Bad Volt Generation? | jp_costarica | General Yaris / Vitz Discussion | 4 | 06-14-2012 04:56 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
