Old 05-13-2007, 03:26 AM   #1
Walter
Walter's Avatar
Drives: Polar White LB
WTT + cash= transmission in SoCal
Some of you may have bought a manual and now wish you had a automatic... or if youre going to trade the car in or sell it, and want more value (automatics are worth more $).
I have an automatic LB and Im looking to trade transmissions with someone with a manual (all included, ECU, gearbox, pedals, cluster w/tach, etc). Ill take care of the labor costs.
Let me know if youre interested.
Thanks
Walter is offline
Old 05-13-2007, 03:45 AM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Thanks
The manual transaxle is the C50 and has been around for some time. I would start searching for one at the local wrecking yard. Hell, while your at it you could do a rebuild with different ratio depending on your type of driving. For instance if I did not need to tackle step grades possibly a 5th gear overdrive that drooped my RPM's down considerably at highway cruising speeds?
It looks like the C52 might also bolt up, but am not positive. That is a stronger trany then the C50 and might offer better ratios?
blacksan is offline
Old 05-13-2007, 04:05 AM   #3
Walter
Walter's Avatar
Hmmm, thanks... what cars did te C50 come in?
Even if I find a tranny, I believe that the biggest issue is going to be finding a ECU that will work...
Walter is offline
Old 05-13-2007, 04:08 AM   #4
blacksan
blacksan's Avatar
Hmmm, I really can't say when the C50 was first used, but the MR2 had it in the early models. Let me dig a little more and see.
blacksan is offline
Old 05-13-2007, 04:11 AM   #5
Walter
Walter's Avatar
Hmmm good deal, thanks!!!
Walter is offline
Old 05-13-2007, 04:16 AM   #6
blacksan
blacksan's Avatar
No prob, I am a gear head and enjoy learning about new stuff all the time.
blacksan is offline
Old 05-13-2007, 04:38 AM   #7
blacksan
blacksan's Avatar
You know a shift kit and some different viscosity fluid might get you what you are looking for in your slush box. What is your goal?
blacksan is offline
Old 05-13-2007, 04:40 AM   #8
Walter
Walter's Avatar
I like having control, just used to having a manual I guess. Driver involvement is a big thing for me to have fun when drivng... and I want to eliminate the lag that comes from "gear hunting"
Walter is offline
Old 05-13-2007, 05:16 AM   #9
blacksan
blacksan's Avatar
I fully understand. It took me a couple of weeks to find a manual trans in a Yaris. I bet there are a few in the scrap yard already. Have you tried the local wrecking yard yet? They operate off a nation wide data base (most often) and can find you parts pretty quick these days.
blacksan is offline
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
Transmission needs to warm up????? bojim General Yaris / Vitz Discussion 9 01-01-2007 05:49 PM
