Old 05-13-2007, 05:05 AM   #1
Walter
Walter's Avatar
Drives: Polar White LB
Originally Posted by blacksan View Post
The manual transaxle is the C50 and has been around for some time. I would start searching for one at the local wrecking yard. Hell, while your at it you could do a rebuild with different ratio depending on your type of driving. For instance if I did not need to tackle step grades possibly a 5th gear overdrive that drooped my RPM's down considerably at highway cruising speeds?
It looks like the C52 might also bolt up, but am not positive. That is a stronger trany then the C50 and might offer better ratios?
Hmmm, thanks... what cars did te C50 come in?
Even if I find a tranny, I believe that the biggest issue is going to be finding a ECU that will work...
Walter is offline
Old 05-13-2007, 05:08 AM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Hmmm, I really can't say when the C50 was first used, but the MR2 had it in the early models. Let me dig a little more and see.
blacksan is offline
Old 05-13-2007, 05:11 AM   #3
Walter
Walter's Avatar
Hmmm good deal, thanks!!!
Walter is offline
Old 05-13-2007, 05:16 AM   #4
blacksan
blacksan's Avatar
No prob, I am a gear head and enjoy learning about new stuff all the time.
blacksan is offline
Old 05-13-2007, 05:32 AM   #5
Walter
Walter's Avatar
Awesome, I started to do some research and just found this online... on a AE92 page
"Did you know that the Mk1 AW11 N/A MR2 (damn... that was a lot of letters in there, huh?!) has the same C52 tranny as the AE92 GT-S? If you're thinking about going to the wrecking yard and finding an MR2's tranny to replace your tired tranny in the AE92... FORGET IT!!! Remember, the MR2's drivetrain is behind the passenger cabin. Thus, the AW11's shifter mechanism is on the opposite of the AE92's. You're always free to crack the case open and see if you can swap the shifter mechanism's internals, but you're on your own here!"
Walter is offline
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 02:45 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 04:51 PM
Transmission needs to warm up????? bojim General Yaris / Vitz Discussion 9 01-01-2007 06:49 PM
