![]() Drives: Beater 10 yaris 3dr HB XP90 Join Date: Oct 2025
Frs seat
I have installed the driver side seat off an unknown FRS year module of marketplace for $100 bucks a seat. Guy ran outa Brz seats since heated seat would have came into the conversation.
I didn’t install it the proper way however it is in and bolted using the Frs frame and seat, just swapped the seat belt and wiring over. Frs seat rails are more narrow and longer so the back of the rails do poke out a few inches more than stock. I have a 2 door so doesn’t bother me. Drilled into the frame for the front left hole and left rear is floating but will need to weld a bracket fit correctly. This seat is a few inches lower even with the seat cranked to highest setting so if you are around 5ft 8 might take some getting used to as blind spots increased. Seat squeaks on the bolsters Hoever… it does feel really good and road and shift feel is more direct. 14.5in y axix stock 18.5in x axis stock — 15 3/4in x axis Frs 16in approx y axis Frs |
| 1KR-FE hatchback vs 2NZ-FE Sedan | tamrat | General Yaris / Vitz Discussion | 5 | 07-07-2016 12:02 AM |
| Sedan vs Hatchback Instrument/Gauge Cluster | goku87 | DIY / Maintenance / Service | 3 | 08-26-2009 11:26 PM |
| Why people choose a 5dr Liftback instead of a Sedan?? | SimmZ | General Yaris / Vitz Discussion | 53 | 05-29-2007 10:28 PM |
