Old 01-01-2026, 02:43 PM   #4
YOUNG SCOOTER
Drives: 2008 Toyota Yaris Hatch
Things to do to get piece of mind
-replace all 4 spark plugs. Not hard and not expensive
-put a can of sea foam in the gas tank
-get MAF sensor cleaner (not throttle body or carb cleaner) and take apart the intake tubing and deep clean the sensor and also spray some into the throttle tubing and the throttle opening.
-new air filter
change oil
then nice long 1 hour drive on the interstate
If still having problems you'd probably want to take it in to toyota to have the transmission fluid changed. Used to have a grand marquis that would slip out of torque converter lockup in 4th gear and sort of feel like a soft misfire. Had 100k miles on the trans fluid, changed it out and it never happened again.
YOUNG SCOOTER is offline   Reply With Quote
Temu Bonus Code {"1,000 kr off"} {ali259660} First Time Users Shreeji General Yaris / Vitz Discussion 0 10-17-2025 12:40 AM
Temu Coupon Code 1,000 kr off Norway {ali259660} First Time Users Shreeji General Yaris / Vitz Discussion 0 10-17-2025 12:39 AM
Temu Coupon Code 1,000 DH OFF [ALH199386] for Existing Customer earlyrest General Yaris / Vitz Discussion 0 10-08-2025 11:46 AM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
