Old 02-29-2024, 06:43 AM   #325
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
I have made no modifications, yet get 40mpg tank after tank. 2013 HB LE, stickshift. Mostly it is driving style. Coast as much as you can. Downshift to brake, because when engine braking the fuel is shut off. I accelerate like a rabbit, working to get to 5th gear. I usually go from 3rd to 5th. Once in 5th I then drive with a light touch on the pedal.
If I am doing 100% highway speeds (+70mph) my mileage will not be as good. The Yaris loves country roads that go through hills, as long as you don't have to slow too much for curves.
I'm at 190K miles. No repairs. Just changed the rear brake shoes, the front pads are still fine.
Amdkt7 is offline   Reply With Quote
Old 05-12-2024, 01:43 AM   #326
Keith Mitchell
Drives: 2014 Yaris YRS
Hi All. In reading the OP, and him saying he never goes over 2000rpm, my 2014 YRS at 65mph, the maximum speed limit in Australia is revving at 3100rpm. Is this normal or has my Yaris got a mechanical issue? I would suspect at 55 the revs won’t drop much and definitely not to 2000rpm? So downhill under brakes my Yaris downshifts (auto). Also have a 2012 Camry at the same speed is doing 2200rpm..
Keith Mitchell is offline   Reply With Quote
Old 02-15-2025, 10:09 PM   #327
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
Hi Keith - revs/mph you indicated seem right on. MT is around 3000 @ 60mph, so that tracks. Not going over 2000RPM could be interpreted two ways: in 5th gear never going above ~50/55mph, and/or always up shifting at 2000RPM to keep overall rev average low. I do that myself as most of my shifting on daily commute is on flats and rarely go above 2k other than the big uphill on the way home, but even then, 3rd gear at 35mph is barely above 2k.
His grace is sufficient.
SeaYa is offline   Reply With Quote
Old 01-02-2026, 11:44 PM   #328
Sissy
Drives: 2015 three door, polar white
2015. I've gotten 36.5 mpg max. Stop and go traffic, long, long red lights.
Sissy is offline   Reply With Quote
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Fuel consumption US Yaris vs. Canadian Yaris Driver Performance Modifications 8 10-29-2006 02:27 AM
