Old 02-28-2026, 08:21 PM   #1
timjamz
Drives: 2007 Yaris Sedan MT
Well, I've replaced the thermostat and water pump now. Even after refilling the coolant and letting it bleed air for about 30 minutes, still the lower radiator hose is cool. Unless I'm doing something significantly wrong in draining/filling the coolant such that I've got a massive air pocket, I can only assume this motor just runs really cool under normal conditions.
timjamz is offline   Reply With Quote
Tags
coolant, thermostat
Weird lighting issue, bulbs replaced and fuses checked... 07liftback DIY / Maintenance / Service 19 11-13-2024 12:21 PM
Weird starting issue shepd DIY / Maintenance / Service 7 03-22-2016 11:20 PM
Weird starting issue 2007 auto yaris Nask26 DIY / Maintenance / Service 11 07-28-2010 12:29 AM
Weird issue during braking xtremesniper Canada 21 06-04-2009 11:00 AM
