Old 03-16-2026, 10:57 PM   #1
poohbears helper
Drives: not yet owned
Wow... so grateful
Took my inner panels off during a miserable, prolonged, cold rain storm here in Northern Idaho, and your description is nearly identical to my issues.
I found 4 leak areas, and will travel down your road of investigation, always sort of looking over my shoulder in trepidation as I try to figure out the clips... each pop so far has done the right thing, not yet broken any, but I have not yet gotten into the upper ones where the seat belts are, nor have I opened the head liner.
I may skip those based on your findings and seal up the areas you spoke of first, in hopes I won't have to go there. I know my seal around the door is not sealed well any more. I can't thank you enough for taking the time to write out your process, the parts that you relate regarding what you investigated that did *not* yield problems are as valuable as knowing what did. Thank you ever so much!
I discovered that I'm also missing what is called the Rear Bumper Side Seal (Left hand) Part Number:#52592-52220, which covers over the bumper interior area right behind the rear wheel. That seal must have been jettisoned when someone prior to me replaced the bumper, and it prevents a lot of slop and mud from getting into the rear bumper area, so I'm hoping that replacing that will help. I'm seeing a lot of places under the rear bumper that might also want to be sealed.... especially on the side where I believe there was a prior impact, but I'm not sure how much to do. I don't want to trap water inside between two panels, so am feeling a bit cautious about how much to do there. Any advice would be welcome with that.
poohbears helper is offline   Reply With Quote
hatch leak, leak, leaking, roof leak, water damage
Toyota Yaris hot hatch on the way following WRC return! VitzBoy General Yaris / Vitz Discussion 15 12-19-2016 11:01 PM
2012+ Yaris rear hatch curvature for spoiler yarisugi Third Gen Yaris General Discussion 5 07-10-2015 02:59 AM
