Old 05-15-2007, 02:01 AM   #32
ChinoCharles
Drives: LB
Taken from http://en.wikipedia.org/wiki/Throttle_body
In a fuel injection engine, the throttle body is the part of the air intake system that controls the amount of air flowing into the engine, in response to driver input. While the accelerator is often called a "gas pedal", it would be more accurate to describe it as an "air pedal".
The throttle body is usually located between the air filter box and the intake manifold, and usually attached to, or near, the mass airflow sensor.
The largest piece inside the throttle body is the throttle plate, which is a butterfly valve that regulates the airflow.
On many cars, the accelerator pedal motion is communicated through the throttle cable, which activates the throttle linkages, which moves the throttle plate. In cars with electronic throttle control (also known as "drive-by-wire"), an electric motor controls the throttle linkages and the accelerator cable connects not to the throttle body but to a sensor. The Engine Control Unit (ECU) determines the throttle opening.
When the driver presses on the accelerator pedal, the throttle plate opens up, allowing more air into the intake manifold. Either a throttle position sensor or an airflow sensor measures this change and communicates with the ECU. The ECU then increases the amount of fuel being sent to the fuel injectors in order to maintain the desired air-fuel ratio.
Throttle bodies may also contain valves and adjustments to control the minimum airflow during idle. Even in those units that are not "drive-by-wire" there may be a small electric motor that the ECU uses to modify the throttle opening.
Many cars have a single throttle body, however more than one may be used, chained together by linkages, to improve throttle response. At the extreme end, cars such as the BMW M1 have a separate throttle body for each cylinder.
A throttle body is somewhat analogous to the carburetor in a non-injected engine. Carburetors combine the functionality of the throttle body and the fuel injectors into one, that is, to modulate the amount of air flow, and to combine air and gas together. Cars with throttle body injection (called TBI by General Motors and CFI by Ford) locate the fuel injectors in the throttle body, thereby allowing an older engine to be converted from carburetor to fuel injection without altering significantly the engine design.
Its basically like having 4 separate intakes on your car. Crazy stuff.
toyotafest 2007 esquiva California 3 05-14-2007 07:26 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 07:09 PM
2007 Yaris or 1999 Mercedes ClK430 jamal1984 Off-topic / Other Cars / Everything else Discussions 9 03-19-2007 10:27 PM
2007 Registration and Insurance Vitz-to General Yaris / Vitz Discussion 21 03-28-2006 10:57 PM
