Old 05-15-2007, 04:02 AM   #1
spkrman
Drives: 1
That was actually my radar detector, and then blowoff valve :)
When you hit the governer, you def know it... the car basically takes the throttle off, even though your still flooring it. I assumed I had found the top speed before, but that was just the car running out of power lol This was definitely the governer... and I'd say the top speed has yet to be defined, I bet it could hit whatever the tranny limits it to as it was just getting back into the peak power band.
~125 was pretty fun, it wasn't really unstable... but it definitely didn't feel planted all the way up there.
Old 05-15-2007, 04:26 AM   #2
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
So the automatic tops at 125, but do we know what the 5spd tops at with Turbo?
TurboYaris?
Or at least do we know what an Xa Turbo tops at with 5spd.
Old 05-15-2007, 01:46 PM   #3
spkrman
Drives: 1
TurboYaris?
The rims throw off the speedometer, 117 on the speedo is actually 125.
Old 05-15-2007, 02:18 PM   #4
hahaha, i thought it was a chime, like what they have in Japan (at least from Initial D )
Old 05-15-2007, 02:29 PM   #5
spkrman
Drives: 1
lol
Dude, the dubs need to go! Put them in the garage for shows and grab some real rims so you don't pit your chrome tearing your new turbo to bits. I'll bet you're carrying damn near 37 MPH into second. Still doesn't make it a Ferrari killer, but its bearably fast now.
The end of 2nd is right around 70mph. Manually shifting out of first used to make quite a difference 0-60, it goes too fast now to time it out perfectly everytime though... it doesn't exactly shift exactly when i throw it to 2... 1st can be held to almost 40mph... pretty crazy... this is why I want to try a set of shorter tires.
I'll grab a set of 15's soon, along with the lightweight crank pulley... and, well, not alot more that can be done until some tranny work is performed.
I may look into a boost controller, I think up to maybe 9 psi would be safe if not used constantly... more than anything I'm curious as to how it would perform.
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 05:35 PM
I want to know what is the speed, acceleration and gas mileage of my Yaris kidman General Yaris / Vitz Discussion 13 05-08-2007 04:10 PM
top speed? cptsenestpc General Yaris / Vitz Discussion 33 11-01-2006 04:21 PM
