Old 11-14-2009, 08:56 PM   #1
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Silverglow,
I very much agree with your opinion of lighter weight oils-after this sample I drained the oil and refilled with RLI 0W-20.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 11-17-2009, 06:53 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Someone at BITOG just spectrochemically analysed the 0w-20 Toyota oil, and its Japanese import by IDEMITSU and its prob the best 20wt out there. Japanese love moly and it has TONS of moly. Same is tru with the Honda OEM oil. I hear its under 5 bucks a litre too and a full real synthetic, unlike syntec and synpower and PP which are fake synthetic - just severly processed Dino oil. So hit the dealer and give it a try.
TheSilkySmooth is offline   Reply With Quote
Old 02-27-2010, 10:04 PM   #3
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
I've been following topics relating to 5w20 oils for a while with regards to various makes and models. The most enlightening post I have seen was made by an (I believe Ford) engineer involved in oil testing. He went so far as to say that while 5w20's protection was considered acceptable, and resulted in a 1% or so increase in MPG, which is good for the manufacturer's CAFE, that actual wear was significantly greater for 5w20 than for 5w30. And that he, personally, did not use 5w20 for that reason.
I use 5w30 for the same reasons.
P.S. I'm not sure if this has already been mentioned in this thread, but all the TSB is saying is that Toyota is (retroactively) switching to GF4 oils from GF3. Read the second red box on the TSB carefully. It clearly states that viscosity requirements vary by model, and that you should use the viscosity stated on the filler cap. All the 5w20/0w20 stuff is about what they are doing with new engines.
sbergman27 is offline   Reply With Quote
Old 03-02-2010, 09:56 AM   #4
TheSilkySmooth
I have been saying this for years. If 20wt was OK, then the newer yaris would be spec'd for it and they are not. Thats not saying 5w-30 GF4 is a good oil. I would be hunting for a 10w-30 SJ or SL outdoor equipment oil for high stress applications. John Deere, Briggs and Stratton and mTD all make good HD oils - dont tlet the lawnmower/tractor bother you - these engine are air cooled usually have NO oil pump or filter and run at wide open throttle mid-high load. 4-stroke marine I/O engine oils are stout too.
Old 03-02-2010, 01:02 PM   #5
1stToyota
1stToyota's Avatar
It'd be neat to see a UOA on a modern car like ours that ran something like B&S's synthetic oil for one of its OCIs. I know they're designed for higher temps.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 03-04-2010, 12:50 PM   #6
sbergman27
sbergman27's Avatar
...dont tlet the lawnmower/tractor bother you...
Actually, *do* let the lawnmower/tractor bother you. It's a completely different application. The requirements for these engines are completely different than for automotive applications. And you can't view oils along a one dimensional metric of "good" and "bad". That's far too simplistic. Oils are formulated for the specific application they are intended for. An oil may be (and probably is) superlative for your tractor but totally inappropriate for your car, and vice versa. (Although I should note that Scamsoil's marketing department *does* deceptively use *gear oil* metrics like the "four ball" test to market their snake oil products.)
On the topic of 10w30 vs 5w30... A 5w30 oil at 0F is thicker than a straight 30 wt at operating temperature. In fact, probably thicker than is optimal. All 10w30 is going to do is increase the starter load a bit.
Use what the manufacturer advises instead of doing all this armchair second guessing.
A possible exception to that, which may have some slight advantages, might be substituting a 0w30 for 5w30, if the (reputable) oil manufacturer rates it to be a suitable replacement for 5w30.
Old 03-04-2010, 02:27 PM   #7
1stToyota
1stToyota's Avatar
That's what I did at my last service, substituted Mobil 1 0w30 for the PP 5w30 that I usually use...bottle claims to exceed 5w30/10w30 requirements so I thought I'd give it a try.
2008 Scion xD
Old 03-04-2010, 07:34 PM   #8
TheSilkySmooth
Actually, *do* let the lawnmower/tractor bother you. It's a completely different application. - MTD (Olympic) is API SJ rated - no problem - unless the "proper" % of EP agents bother you.
On the topic of 10w30 vs 5w30... A 5w30 oil at 0F is thicker than a straight 30 wt at operating temperature. In fact, probably thicker than is optimal. - All oils are thicker when cold than at op temp. An oil with a improved VI may provide small gains in FE during warmup but are minimal at best.
Use what the manufacturer advises instead of doing all this armchair second guessing. - I will not sacrifice EP wear protection in the false hope of having my cat converter last 300K miles with "green" ILSAC gf4 spec oils.
A possible exception to that, which may have some slight advantages, might be substituting a 0w30 for 5w30, if the (reputable) oil manufacturer rates it to be a suitable replacement for 5w30. - Unless operating in the arctic circle, I find PAO base fluid show much higher engine wear and noise due to these fluids poor lubricity v. group I/II base fluids. I know I'm runnning M1 AFE 0w-30 now and I am not convinced of any benefit - my fuel mileage is much worse (-5mpg) on a 5 tank average than last winter's mean running a 5w-30 pennzoil conventional
What else?
Old 03-04-2010, 11:18 PM   #9
sbergman27
sbergman27's Avatar
What else?
Yes, all multivis oils are thicker at cold temps than at operating temperature. I mentioned the fact because it is widely misunderstood, and people who do that tend to recommend 10wX oils or straight weights.
I would not expect to be able to measure the difference between AFE 0w30 and a 5w30 without a lot of very systematic testing. I seriously doubt that your 5 mpg difference has anything at all to do with the oil.
Engines don't see EP. They see sliding friction under very high shear conditions. Lot's and lots of it. What, exactly, do you think that extra EP additives are buying you? And what are the down sides, I wonder?
You are, of course, free to second guess the engineers as much as you please. Especially if you are out of warranty. But you do it at your own peril. And I'd be particularly nervous going further and telling *other* people to use it.
That said, if you are looking for an impressive oil that meets a range of European (and particularly German) high performance standards which almost no other does, and has an HTHS of 3.7... look to Mobil 1 0w40. If I were going to stray from the spec'd 5w30, that's what I would use.
http://tinyurl.com/39b6cg
BTW, why don't you care about your (and other people's) catalytic converter?
-Steve
Old 03-05-2010, 10:30 PM   #10
TheSilkySmooth
I would not expect to be able to measure the difference between AFE 0w30 and a 5w30 without a lot of very systematic testing. I seriously doubt that your 5 mpg difference has anything at all to do with the oil. - Agreed. I have a failing converter and it's attendant high backpressue, also the winter fuel seems worse than last season - though my converter may be confounding diagnosis.
Engines don't see EP. They see sliding friction under very high shear conditions. Lot's and lots of it. What, exactly, do you think that extra EP additives are buying you? And what are the down sides, I wonder? - - I am assuming periodic EP due to piston cocking at stroke ends - though the 1NZ has a designed wrist pin centreline offset to minimise this. Cam loads can get high, but only during valve float caused by oil ash buildup on thier heads and periodic sticking due to infrequent high RPM excursions. Maybe I do want a higher HTHS after all - or maybe just a bit more viscosity. When using oils with > 0.1% EP; My engine uses little oil so I dont worry about converter loading with metal thiophosphates.
You are, of course, free to second guess the engineers as much as you please. Especially if you are out of warranty. But you do it at your own peril. And I'd be particularly nervous going further and telling *other* people to use it. - I would imagine Engineers would prefer no exhaust aftertreatment worries, and more safety margin from the energy conserving lubricant we use. The EP and HTHS was not reduced in North America to benefit the engines or its longevity.
That said, if you are looking for an impressive oil that meets a range of European (and particularly German) high performance standards which almost no other does, and has an HTHS of 3.7... look to Mobil 1 0w40. If I were going to stray from the spec'd 5w30, that's what I would use. - Agreed its EXxon-Mobils' best effort as is The M1 racing 4T superbike oil, but I am no fan of PAO bases where they have no pronounced benefit. I doubt the VVTi hydraulics would allow enough cam advance at lower RPMs with the higher viscosity of a light 40wt - it's overly sensitive and likes an 10-11 cst oil to be in its sweet spot.
BTW, why don't you care about your (and other people's) catalytic converter? - I care about my converter - but mine usually fail due to suspect incorrect mixture and high heat loading brought on by misformulated E10 fuels - not a pinch of dithiophosphate here or there.
-Steve
Steve , I really appreciate you reasoning
Old 03-04-2010, 09:57 AM   #11
TheSilkySmooth
Yeah - I like to do that but the cost is high since I'm out of work. Plus I'd need a trend of over 2 OCI. So that would be 3 UOA. I'll run the stuff and see if it runs smooth, revs hard and quiet to redline, and show reasonable fuel mileage - thats good enough for me. I think these oil just have the old higher level of ZDDP, no friction mods, and higher Ca detergent. OTW they are the same as PCMO's. Lowes had B&S syn reasonably cheap ( under 6 a quart) before winter - now its all bought up. Surprised me
Old 03-05-2010, 12:25 AM   #12
Hershey
how about PENNZOIL 5w-30 Utra or EURO synthetic ( ACEA A3/B3/B4 ) in a 5w-30 for the YARIS ? Here's the Technical Data Sheet for the EURO Ultra http://www.pennzoil.com/assets/PZL_U...5W30_01_10.pdf and for the ULTRA ( North America ) , http://www.pennzoil.com/assets/PENNZ...thetic_PDS.pdf . Here's full page for the ULTRA , www.pennzoil.com/#/motor-oil/pennzoil-ultra .
Old 03-05-2010, 01:01 AM   #13
sbergman27
sbergman27's Avatar
Originally Posted by Hershey View Post
how about PENNZOIL 5w-30 Utra or EURO synthetic...
The Euro product looks pretty impressive. Particularly for a 5w30. I didn't know a 5w30 with a 3.68 HTHS existed.
The concern by European high performance manufacturers is with the relatively low HTHS of gf-4 oils with regards to the valve train. Specifically, cam and lifter wear. They feel that 3.5 is required for best protection. Unfortunately, HTHS is also the primary number that determines an oil's fuel efficiency characteristics. And lower is better there.
However, the whole issue of valve train wear and HTHS is probably not germane to our cars. Certainly, my 1988 Chevy Sprint Metro 1.0L 3-cyl with 345,000 miles on the odometer still shows minimal cam wear. And it has always used 0w30 or 5w30 Mobil 1, with HTHS of between 2.99 and 3.1.
Old 03-05-2010, 01:13 AM   #14
Hershey
thanks . Very informative . Therefore the EURO would be fine . Maybe overkill .
Old 03-05-2010, 10:35 PM   #15
TheSilkySmooth
I have seen Motul 5w-30 with a BMW LL-01 spec. I think its marketed as X-MAX currently.
Old 03-09-2010, 07:12 AM   #16
sbergman27
sbergman27's Avatar
BTW, does anyone happen to know where one can actually *purchase* the Pennzoil Euro Ultra 5w30 product in the US. I'm in Oklahoma City and am having problems locating any.
Old 03-09-2010, 10:46 AM   #17
Hershey
WAL-MART may have it . When I called PENNZOIL about the ULTRA he said it was at WAL-MART in TEXAS . So , you being in that region it may be sitting on a shelf . Call them in advance and get directed to AUTOMOTIVE department to see if in stock .
Old 03-09-2010, 10:48 AM   #18
Hershey
so you plan on using the 5w-30 EURO Ultra for your YARIS ?
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
finally found a good product to clean al plastic parts Adriaan Wash, Wax, Detailing, Exterior Repairs 4 12-01-2006 02:45 PM
It's finally here! Cathy New YARIS Purchase Forum 10 08-29-2006 10:08 AM
